1. #61
    Member User Gallery
    Join Date
    Dec 2011
    Posts
    65
    Default
    @nicksc This is looking very good. The hair and body. Is there a tutorial about making that copper oxidized look you have created? Would like to recreated or try, but don't know where to start.
  2. #62
    Senior Member User Gallery
    Join Date
    Jul 2011
    Posts
    296
    Default
    Finally finish my sleeping lion sculpt. Finished it in Zbrush.
    I'm not happy with the main got to redo it. It's not good enough.
  3. #63
    Member User Gallery
    Join Date
    Jan 2006
    Posts
    63
    Default
    It's a beautiful piece.
    Did you sculpted the lion from that base?
  4. #64
    Join Date
    Jul 2011
    Posts
    296
    Default
    Sculpted it from a Sculptris sphere.
  5. #65
    Join Date
    Jul 2011
    Posts
    296
    Default
    Here's how I did it. Starting with a Sculpturis sphere, I created the base using the scale, grab and flatten brush. Then went from there.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	292299   Click image for larger version.
ID:	292300   Click image for larger version.
  6. #66
    Join Date
    Jul 2011
    Posts
    296
    Default
    Quote Originally Posted by Adamx View Post
    Adamx, I did the cooper finish in zbrush, very easy in zbrush
  7. #67
    Member User Gallery
    Join Date
    Dec 2011
    Posts
    65
    Default
    Quote Originally Posted by nicksc View Post
    could you share a little more on the process. Does it involve PS?
    Thanks.
  8. #68
    Join Date
    Jul 2009
    Location
    Athinai
    Age
    55
    Posts
    2,484
    Default
    I'll answer this. Obviously, it does not involve Ps.
    Wonderful and I may say, cute lion sir!
  9. #69
    Join Date
    Jul 2011
    Posts
    296
    Default
    I'm not sure what PS is?
  10. #70
    Join Date
    May 2010
    Age
    32
    Posts
    530
    Default
    PhotoShop
  11. #71
    Join Date
    Jul 2011
    Posts
    296
    Default
    Thanks Serek, no it was not done in PS
  12. #72
    Join Date
    Jul 2011
    Posts
    296
    Default
    Here is another sample of this rendering style. Creating this texture was as easy as selecting an appropriate material and pressing the bpr render button in Zbrush.
ID:	292457   Click image for larger version.
  13. #73
    Join Date
    Jul 2009
    Location
    Athinai
    Age
    55
    Posts
    2,484
    Default
    Oh it looks great! Serious sculpting!
    MAtcaps in zb is a fast solution for previewing. Never renders well though. It reacts badly with casted shadows.
    Subdivide at >2M first.
    New zb4r2b has a great great way to create cavity and AO masks. Mask the cavity area, fill with color, invert the mask paint again etc etc. Paint using textures too. Then, use a default zb shader and play with reflections.
    Or, create a low poly version, make UVs (UV master), subdivide at 2-4M / reproject and do the same painting job. Now you can bake and export to a more decent render engine.
    Sculpture loves these global illumination render engines.
  14. #74
    Member User Gallery
    Join Date
    Dec 2011
    Posts
    65
    Default
    Quote Originally Posted by michalis View Post
    Why "obviously" ? There actually is a technique to do it using PS. After sculpting, two images are rendered with identical pose.One with new copper other with oxidized color. Next you use layers in PS to achieve the desired look erasing some of the top layer where you want the oxidation to show. However, I don't like doing it this way, because you are just treating the image, and not the sculpture. And yes, the lion is cute.
    Cheers.
  15. #75
    Join Date
    Jul 2011
    Posts
    296
    Default
    Adamx, if you have Zbrush it will be easy for you to create this affect. I appreciate you explaining how it can be done in PS, I will try it just to learn something new. It seems that michalis has alot of experience with Zbrush, so that's why it would be obvious to him. However I think your question "
    could you share a little more on the process. Does it involve PS?" is a great one. I struggled trying to create this affect until I got zbrush. Technically I am very weak, However if you have zbrush I will help you achieve this affect the best I can. One thing you may want to do is go to the pixologic web sight under the download center and check out the Mattcap library. That's where I found what I needed to create the latest images you see on this thread, Except for my sleeping lion, I made that with the lightcap tool. Hope I've been helpful. Good luck.
Page 5 of 8 FirstFirst ... 2345678 LastLast
Posting Permissions
  • You may not post replies
  • You may not edit your posts
