Yes, I did mean "move the slider all the way to the Right (or Left) 10 to 15 times." Moving the slider fully to the side creates one full twist.
There is a cut and paste typo after Step 3, seemingly titled !0. It's simply part of Step 3, a tweak to the initial inflate.
Mirror is in the Deformation Pallet. If Mirror creates a braid with the chevron effect of braiding pointing up, instead of down, rotate the merged braid 180 Degrees as you noted. Then tapered accordingly, with the chevron pointing toward the tapered end.
Thanks for your help; I'll work on clearer instructions,
Katherine Dewey, not all that wise in the ways of ZBrush
Pixologic ZBrush Blog
I woulda never thought up this trick!
