1. #1
    Member User Gallery
    Join Date
    Apr 2007
    Posts
    64
    Default GoZ problem
    when press GoZ to maya nothing is coming in maya the outline is just blank on mesh nothing... pls help
    Thanks ,
    Ronybuster
  2. #2
    New Member User Gallery
    Join Date
    Feb 2006
    Posts
    15
    Default
    i had the same on max and i reset the scene, it helps.
    but also use "search" option=> lots of peoples have problems with correct path to the maya, maybe you have to fix that path by hand.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
