Wow! Thank you thank you! Last render is amazing! I hope this goes top row not just for the works but for the contribution also!
SketchBook
ZAnimator (Video Demo): The Zbrush Animation Plugin (Keyframe and Timeline based)
ZAnimator Zbrush Thread
Blog / Webfolio: Darukin's Arts and Crafts
***65330;eally awesome render!!!
Thanks for sharing!
Kouji Tajima - Concept Artist/Creature Designer/Modeler/Texture Artist/
PORTFOLIO
Thanks a lot for sharing the shader and great work, both sculpts and the render mate.
5*****
Sohrab Esfehani
sohrab.esfehani@gmail.com
thanks a lot Ralf. Great shader to show off sculpting.
a suggestion about shadow settings. setting the angle to 0 and cranking the res all the way up to maximum gives you the most detailed and precise shadows, while still rendering fast. the softness can then be solely regulated by the blur value.
wow! thanks a lot!!
chem!
great workand thanks for sharing mat and Render setting
awesome! thanks for sharing your shader and rendering setup!![]()
sweet ... nice stuff and thanks for the shader ...
Thanks for this Ralf, but i have a problem with edges and shadows. can you help me?.
Once again I wanted to say thanks for the shader Ralf, it's one of the best presentation matcaps I've ever used for Zbrush, such great presentation shader!
And you have the cleanest works bro! Keep it up!
SketchBook
Not sure if this is it but make sure you increase the size of your document. It may just be a lack of resolution on the render.Originally Posted by PolarWolf
If I may: for an edges solution, render using AAhalf (CTRL/CMD Number Pad 0) So having a document size that is double your final desired output is where to go.Originally Posted by PolarWolf
As for BPR shadows, increase Rays, or Blur. Resolution helps but the first two will get you there. For harder shadows, use low ray count, still use a touch of blur, and a low Res. From there, adjust to taste..lol!
Also, if you increase and tweak your AO, that would also help the shading/shadows. I don't see any ao between the lips.
Thanks so much Ralf. Cool Material.
Blaine
Anchorage, Alaska
Chillllllllllllllin
Thanks alot for render settings and material.![]()
